2000 Convert Top Issue
Old Jan 30, 2007 | 02:50 PM
robber's Avatar
Default 2000 Convert Top Issue
Done a lot of searching on the various forums and I beleive that my need to have the convert mechanism recalibrated.
The issue is minor as of now. The top will go up and down on its own with a single button press, however- when the top is almostall the waydownit doesnot completely rest back into the storage compartment- it stays slightly elevated in the storage compartment- it is almost not even noticable.The the storage compartment coverthencomes down, hits the top andstops for assecond,and thenfinally forces it to fallinto place which completes the cycle. I am not sure how much force it actually takes, but thecover slows/stops when it hits the rag top, and then it is almost like it pushes it into place and it falls completely into the storage compartment.
I guess I have a couple of questions;
1. Is this an issue?- it seems like the problem is intermittent but getting worse- although it could be my imaginiation.
2. If this is an issue-whatamI looking at to get it fixed?
3. Should I stop using the top altogether until this is resolved?
Thanks a lot.
-Rob
Old Jan 30, 2007 | 08:57 PM
Default RE: 2000 Convert Top Issue
Have you had the Dealer recalibrate it?
Old Jan 31, 2007 | 06:38 PM
robber's Avatar
No, net yet. If that definitely the issue?
Thanks
Old Jan 31, 2007 | 08:48 PM
BIGDAN's Avatar
Is the top button flashing? If it is there is a fault but then again if it was flashing or staying on it would start beeping as you started to move. When the top is being stored the rear latch motors bring the cover down. the the cover latches pull the cover plate the rest of the way down and locks. I think what you see is normal. But still you might run by dealership as I cannot see what exactly it is doing.
Dan
Old Jan 31, 2007 | 09:03 PM
They will look at the Numbers from the Sensor and see if they are out when they calibrate it.
That will tell them if the sensor is bad.
Old Feb 10, 2007 | 11:35 AM
robber's Avatar
Thanks a lot guys.
pacificnw2011
Sep 5, 2010 07:42 PM
thomaskr
Apr 2, 2010 08:30 PM
Scott6
May 29, 2009 06:00 AM
volvodad
Feb 15, 2009 09:18 AM
joey99
Suspension
Mar 23, 2008 08:59 AM
