Volvo switch blade convert?
Old Oct 8, 2008 | 10:32 PM
Scott6's Avatar
Default Volvo switch blade convert?
I herd that if I buy a uncut Volvo switch blade key on ebay, I cant open my remote and put the chip in the blade key and get it cut and a locksmith?
True or False?
Old Oct 9, 2008 | 07:16 AM
Default RE: Volvo switch blade convert?
I think the chips are way different and there is no way to do it. But I have also never tried.
Old Oct 9, 2008 | 11:55 AM
cjones16's Avatar
O ya the Chip from the remote to the switchblade are exactly the same and can be switched out
http://forums.swedespeed.com/zerothread?id=62114
Old Oct 9, 2008 | 09:51 PM
Scott6's Avatar
Nice! thanks alot!
but one question.. when I get the New (form Ebay) Switch blade, who can cut it? Do I need the dealer to cut it, how much will that cost me? or I can just go to a lock smith?
Also, is there a chip in the regular key I need to worry about?
In his post her says: What does # 2 mean?
1. From ebay: Used fob
2. From dealer: New style key, cut , Software , Programming
3. Small screw driver for prying
4. Torx 8 driver
5. Small Phillips driver (maybe)
Old Oct 10, 2008 | 07:56 AM
That is cool now I know.
Also by looking at it the Key itself will need to be programmed. But the remote can be swapped.
Old Oct 10, 2008 | 09:33 AM
cjones16's Avatar
ORIGINAL: Scott6
Nice! thanks alot!
4. Torx 8 driver
#2 Means they bought a Used key on ebay and bought the new key (just the blade) from the dealer.
Then they had the key cut to work for his car,
The car has to have software update for it to work with the key
and the key has to be programed to work with the car
Essentially the Software/Programming is one step
The dealership will *probably* charge you full hour of labor to program the key even though it takes 25 Minutes
Old Oct 12, 2008 | 08:07 AM
2002v70's Avatar
You can do it like the guys that install remote start systems. They take one of your original keys with the transponder chip and tie wrap it to the steering column under the plastic cover near the receiver. Then your car will start with any key that is cut for your ignition or with the remote start in their case. This way you can buy a switch blade from Ebay and get a new key part cut and swap the remote guts. A lot of work for a cool key, and oh yeah with the key attached to the column, the theft deterrent system is now deactivated.
Old May 29, 2009 | 06:00 AM
tpsells's Avatar
The chip is in the key portion. Having a new key cut will not solve your problem. I repair the switchblade mechanism. Professionally done . Guaranteed. Tony P amp1117@yahoo.com
burberry
Apr 2, 2013 11:10 PM
diehardgator1
Aug 19, 2008 07:13 PM
gmorgan
Jun 7, 2007 06:39 PM
mingster
May 18, 2006 09:15 PM
Swish
Apr 10, 2006 09:01 PM
