2007 c70 brake issue
Old Nov 12, 2016 | 07:46 AM
rodneygt's Avatar
Default 2007 c70 brake issue
This is my daughters car. 135k miles. We've had it about 3 years since 80k miles.
Last weekend I put new front pads and rotors on. I bled them without issue. Yesterday I jacked up the passenger side rear and put new pads on. I bled it with no problem. Then I jacked up the drivers side and installed new pads but it will not pressurized and the piston will not go back out.
After putting it back together, it brakes about the same as before all of my work - ok with a slight pull to the right. I do not believe the drivers side rear caliper has been working for some time. The old pads were twice as thick as the old pads from the passenger side.
What can cause this? Master cylinder? Caliper? Suggestions?
The bleeding and attempted bleeding was done with a helper pushing the pedal. The only fluid I got out of the bleeder was when I screwed in the piston.
Thanks.
Old May 6, 2017 | 01:10 PM
rodneygt's Avatar
Thanks.
It was the distribution block of the abs unit. After finally figuring it out by tracing the line to each junction, I bought a used abs unit and swapped the distribution block from it to my old unit. I then had all 4 brakes. Thanks...
huey3110
Dec 16, 2016 06:06 AM
snpklinefelter
Dec 22, 2009 06:26 AM
torres
Jun 29, 2007 03:12 PM
drussell
Jun 26, 2007 06:49 PM
rschleicher
Apr 20, 2007 02:29 PM
