S40 Idle issue, stall issue, erratic Idle issue
Old Oct 2, 2016 | 04:31 PM
huey3110's Avatar
Default S40 Idle issue, stall issue, erratic Idle issue
Guys,
I'm going to link a video I recorded so that you can see and hear the issue rather then me trying to explain it and potentially giving bad info or confusing anyone.
Any input is much appreciated and I appreciate your time.
https://youtu.be/tfHp0EFb9ts
Old Oct 3, 2016 | 08:13 PM
Hudini's Avatar
Failing fuel pump? Just a guess. I'd hook up a fuel pressure tester and see if you get any variation in pressure. Also checks the fuel pressure regulator.
Old Oct 3, 2016 | 10:58 PM
huey3110's Avatar
Fuel pump or the fuel pressure regulator is what I've narrowed it down to as well. Do you know if the FPR would make the check engine light come on?
Old Oct 4, 2016 | 04:35 PM
Hudini's Avatar
Not the fuel pressure itself, that is not monitored on the 2000-2004 1.9L engines. But the resulting misfires and lean/rich conditions sure can.
I would suggest an el cheapo Harbor Freight OBD-II code reader and a fuel pressure tester. Not commercial grade stuff for sure but they both work good enough for the home mechanic. Since these are tools you can use them on any car even after the Volvo is history.
Old Oct 4, 2016 | 04:47 PM
huey3110's Avatar
It's crazy you said that because I ordered one this morning haha. I took the FPR off this morning and was going to inspect it and clean it, and I found the vacuum hose below it was completely broke. You couldn't see it with just a normal visual
Inspection it actually took taking it off. I fixed that and it seems to have fixed it. I would definitely recommend that info to anyone with similar issues as I've spent nearly $400 trying to fix a an inexpensive 2 minute fix. I really appreciate your help and guidance and I really appreciate these forums.
Old Dec 14, 2016 | 09:51 PM
eddieMP12's Avatar
i have the same problem with mine it stalls and dies i don't get any engine codes, i have replaced MAF sensor, Idle valve, i have checked for the vacuum hoses below and by the FPR but they aren not broken they look worn out but their not broken or anything. should i just replace them?
Old Dec 15, 2016 | 07:52 AM
mf70's Avatar
Popular Mechanics has some ideas of how to find a vacuum leak...
How to Find a Vacuum Leak - Smoking Out Vacuum Leaks
Old Dec 16, 2016 | 06:06 AM
Hudini's Avatar
There is another vacuum hose, not just the one connected to the FPR. It's the hose that connects the intake near the throttle body with the front intercooler. It's a large hose and tends to get brittle and snap in two. It's S shaped, about 3/4 inch on one end and 1 inch on the other. There is a part number listed somewhere on the forum.
You can see it here:
Jhow1222
Oct 2, 2013 02:07 PM
AGSchear
Oct 19, 2012 08:26 PM
jwandhistools
Aug 11, 2009 09:43 AM
SPJC
Nov 19, 2005 09:15 PM
ripleydog
Sep 16, 2005 08:38 PM
