2008 C70 how to stop beeping from conv top warning?!!
Old May 22, 2018 | 11:11 PM
Spymann1's Avatar
Default 2008 C70 how to stop beeping from conv top warning?!!
I have a 2008 C70 and the hydronic arm on drivers side leaked out some fluid so the top stoped when only half way opened. I had a professional come out and manually close too but the beeping noise wo t stop and so I have to drive it like this to work every day and its a two hour commute!
When closing the top manually we could not get the drivers side push rod to go back in on the hydrolic arm even after pulling the release lever under back seat and letter the pressure off of pump in the trunk and since weVe had to leave the hydrolic push rod extended it won't stop beeping.
Is there any way to release the pressure on the hydrolic pushrod? If so all I would need to do us reconnect it and I believe the computer would recognize that everything is in correct position.
If there's no way to release pressure is there a way to stop the beeping because by the time I get to work I'm in a foul mood from all the beeping lol. Also does the beeping COMMING from the small tweeters on both doors? If so can I just cut those wires or unplug them?
I would be truly greatful for any help because I've been laid off for a while now and can not afford Volvos $350 charge just to look at it with no promises if it being fixed. Have a blessed day hg.
Thanks
Old Apr 6, 2022 | 08:15 PM
Kar Kare's Avatar
Thanks
did you ever get this resolved? if so can you please tell me the solution. email marshalljulius7@gmail.com
Old Apr 6, 2022 | 08:16 PM
Kar Kare's Avatar
what did you do or have done to resolve this issue?
Guywithacar
Jan 1, 2022 01:58 PM
ritzy4runner
Feb 7, 2021 03:02 AM
fedcep
Nov 15, 2017 04:47 PM
Pski694
South West
Jun 26, 2017 03:44 PM
