2011 C70 Battery Drain
#61
#63
v70 convertible battery drain
I am having the same problem. My husband has to keep charging it and I have bought a new battery. I now do not like using it in case I am stranded or stuck with the roof down. Any information on what could be causing this would be readily accepted! I wondered if anything to do with the alarm. As Usual Marshalls in Cambridge are of no help whatsoever!
Many thanks.
Many thanks.
#64
Battery drain
My battery-drain problem happened when I first got the 2011 C70 as new. Battery drained after I did not use the car for a week (away on vacation). Kept happening over a couple of years despite charging, new battery installation. It turned out to be the radio. I believe it was the Sirius service. I never signed up for Sirius, but somehow the Sirius made the radio be always on and drained the battery.
#65
Hello
In many cases the battery drain was caused by the CRM (Convertible Roof Module) not going to sleep mode after 90 seconds or something i believe it is, we released a software fix for this it should be available to all Volvo dealers. I can not remember exactly when this was. But it was not every car that had the drain problem it was the configuration of equipment that could cause this.
Have a look into this if you have self draining batteries. Remember this only applies to Volvo C70 2006-2013
Hope this helps, it is a real pain in the *** when the car wont start, and also potential damage on the drivers window since it doesnt drop to stay clear of the a-pillar when opening and closing the door so please help the window a bit so you dont break it.
#66
jbarnes
06-12-2013 11:46 AM
volvie!
West
02-24-2011 04:53 PM
