Bad ABS module
Old May 23, 2008 | 08:51 AM
snulma1's Avatar
Default Bad ABS module
So It happened to me....I got the ABS/Brake and flashing winter mode lights of death. As well as my spedo and odometer going blank, so I figure my ABS went sour.
So replacing it, I looked up online and found a guy on e-bay who sells you a refurbed one for 100 as long as you send the bad one back to him. Since I have no use for a bad one I figure that will be good.
But how do I remove it? I understand its beneath the air filter box and the fuse box. But doesn't it require a torx socket? If so, where can I buy one of those?
Is this a fairly straight foward procedure? Other then clearing the codes, is there anything else that has to be done?
Thanks
Old May 23, 2008 | 10:56 AM
snulma1's Avatar
Default RE: Bad ABS module
So I went to Autozone to have the codes pulled, and here is what I found:
P0455 and P0442 which I know are both Evap leaks. I need to figure out how and where to check on these.
But then I got:
P1618, P1633, & P0722. I looked those up on here and am wondering if they are all probably related to a bad ABS module.
smitty86
2001-2013 model year V70
May 7, 2015 09:43 AM
hemi3275
May 5, 2014 07:08 PM
jeepcherokee87
Sep 22, 2010 01:47 PM
NasS80Tbo
Oct 27, 2008 05:23 PM
robohopar
May 5, 2005 05:56 AM
