Belt Diagram & Water Pump
Old Jun 9, 2007 | 01:51 PM
simplex0's Avatar
Default Belt Diagram & Water Pump
First off, I don't have a belt diagram anywhere on my car. In the engine bay... nope. I don't have the owner's manual either and I looked everywhere online including autozone.com. If anyone could send me a diagram that'd be great.
Water-Pump. Where the hell is it. I got 2.3L and I only see a crank, ac, alternator (that I replaced), power steering, and a tensioner. No waterpump.
Someone please help me out, I've been on every site on the internet.
Old Jun 9, 2007 | 02:17 PM
Default RE: Belt Diagram & Water Pump
The water pump is under the timing cover.
The timing belt drives the water pump.
The belt goes around the crank then around the compressor around the idler then the alt. then up around the alt and then tensioner.
Some depending on the belt side will run go around the compressor then the alt. then the idler.
also if you have a newer than 1999 it will have a double sided ribbed belt and that is even different.
Around the crank up and over the idler then the compressor then up to the power steering then the tensioner.
Edit I made what I explained in Paint.
majorcode
Nov 4, 2013 06:41 PM
scrap88
Apr 7, 2010 09:23 PM
katiejoyful
Dec 12, 2007 04:49 PM
ktmrider193
Jun 5, 2007 12:49 AM
