C70 1999 inside lights and alarm
Old May 7, 2015 | 02:17 AM
jonira's Avatar
Default C70 1999 inside lights and alarm
Hi!
I've have some problems with my inside lights. They keep
lightning even if I close the doors and also alarm go on if
I close the doors from remote control. When I close doors manually
with the key alarm doesn't go on but still inside lights keep running.
Of course now I've been taking every inside bulbs off.
Any ideas how to fixit without buying new locks to doors?
Joni
Old May 7, 2015 | 02:42 AM
MSGTUSMC's Avatar
Default Inside lights/alarm
Replace door switches.
Old May 7, 2015 | 03:07 AM
jonira's Avatar
Door switches are inside the lock. One lock in Finland cost 291€ each. Is there any other way to fix it?
Old May 8, 2015 | 02:41 AM
MSGTUSMC's Avatar
Not the electrical switches on the armrest the plunger switch on the body frame the door depresses when closed.
Old May 8, 2015 | 06:31 AM
jonira's Avatar
Default I found out the problem my self
The counterpiece was well-worn so I put some duct tape on that part which you see on picture. Then the central locking, alarm and inner lights is working fine. That´s only temporary solution and I order new parts from Volvo. Only 7,55€/one door including plastic and metal parts which you see on pictures.
Thanks to everyone and hope that my discover helps some one else
Attached Thumbnails C70 1999 inside lights and alarm-img_0729__1431084064_91.157.117.117.jpg   C70 1999 inside lights and alarm-img_0733__1431084204_91.157.117.117.jpg
lovethelysholm
Apr 30, 2011 01:27 PM
VolvoV
Apr 18, 2011 02:57 PM
abc05
Feb 2, 2010 05:10 AM
TomInTN
Nov 9, 2008 05:25 PM
ausman007
Jun 13, 2007 07:52 AM
