C70 antenna
Old Sep 18, 2007 | 01:38 PM
theduke's Avatar
Default C70 antenna
Need Help! Can anyone pls advise how to access and replace antenna on 2003 C70?
Thanks
Old Sep 18, 2007 | 03:00 PM
Shaun Oriold1's Avatar
Default RE: C70 antenna
I'm sadly about to re-install mine today, after my friend broke it on me when I lent him my car.
Remove the plastic bin from the driver side of the truck. unplug the light todo this. and them remove the carpet section there as well.
Lossen the bolts at the bottom of the antenna, on a silver bracket thing - they are 10mm I think
losten the grounding strap with a philips screwdriver
lossen the black nut at the antenna base, on the outsife of the car.
unplug the drain at the bottom, unplug the radio wire, unplug the power..... and wiggle it out.
should take you about 15 minutes if you're not sure on what you're doing....
S.
Old Sep 19, 2007 | 10:38 AM
theduke's Avatar
Thanks for the info, much appreciated.
Old Sep 19, 2007 | 09:57 PM
Glad I can help.
I was wrong in that the grounging strap is a nut as well. cant remember which size. maybe a 10mm like the other bolts were...
S.
Old Jan 2, 2008 | 04:56 AM
sensitiviti's Avatar
Check out this link.
http://www.youtube.com/watch?v=NijL6h5D3l4
It shows you how to change the Power Antenna
Old Jan 2, 2008 | 08:37 AM
Eric J's Avatar
Welcome to the forum,Drew.
That was great input for the forum. A picture says a thousand words, a video is even better.
Why don't you introduce yourself at the 'New Members area' and look around the rest of the forum. If you are a Volvo nut like the rest of us, check in often and spread around your knowledge. Thanks
Old Jan 2, 2008 | 10:50 AM
Turbot's Avatar
Is there any other type of annetena that you can get thats not so styling intrusive. i know that sounds wierd i just think it upsets the flow of the car. well at least the c70.
o yea and the help on this forum is amazing, glad i joined.
bsobo
Apr 20, 2010 08:18 PM
alecw81
Jan 7, 2009 05:22 PM
jetav8r
Feb 22, 2008 07:04 PM
toomany
Sep 5, 2004 12:52 PM
armoredsaintt
Feb 18, 2004 01:54 AM
