C70 Overheating
Old Apr 3, 2009 | 04:58 AM
ICE's Avatar
ICE
Default C70 Overheating
Hi Guys, This morning I was on my way to work and I looked at my temp gauge and it had maxed out and I was like WTF ?! I managed to crawl into work as I was pretty close. right as I was about to park, it started to smoke out of the bonnet and I was thinking...GREAT! another problem. I opened the Hood and the coolant was bubbling out of the cover and after about 20 seconds after turning the engine off it stopped smoking and bubbling. I left it as it was as I had to go to work but any ideas of what that could be ?
I put my foot down only twice on the way to work and it seemed to happen after that. Cooling fan was going crazy when I turned my car off too but i mean thats expected right ?
I changed My MAF last night but that worked fine after a drive. Nothing else has been done.
HELP !
Old Apr 3, 2009 | 09:03 AM
reg's Avatar
reg
Water pump? Volvo redesigned the unit. It is located between the cams and held in by eight bolts. Of course the thermostat may have had a catastrophic failure and failed 'closed' but generally there is a warning with a failing thermostat as you will gradually have a rising temperature.
r.
Old Apr 3, 2009 | 10:29 PM
ICE's Avatar
ICE
r.
so its not a head gasket then ? hmm thermostat or water pump would be much nicer !
I did fill it up with water later that afternoon but it didnt go anywhere, if it were the ater pump wouldnt it hav fallen right through ?
Old Apr 4, 2009 | 06:06 AM
reg's Avatar
reg
Most generally if a head gasket fails you will see plentiful white smoke billowing from the tail pipe. Now I understand that you refilled the radiator and you are not experiencing a high temperature? It would therefore point the finger to your thermostat. Now a word of caution. Do not run 'straight' water through your Volvo engine! Water and aluminum do not make good mates! You must have some coolant which has anti-corrosive qualities contained within it. In fact, I for years (40+) always run a can of water pump lubricant with my bi-annual coolant change.
r.
Old Apr 4, 2009 | 09:46 AM
I would check the thermostat first.
Old Apr 4, 2009 | 09:59 AM
ICE's Avatar
ICE
ok water pump lubricant ?
and thermostat.....phew ! not as pricey a job as a head gasket !
Old Apr 5, 2009 | 07:22 AM
reg's Avatar
reg
Your auto parts store will fix you up with the water ;pump lubricant.............in the U.S. a can is around $1.00.
r.
Old Apr 5, 2009 | 05:10 PM
ICE's Avatar
ICE
r.
ok sweet thanks reg
ludeless
Mar 27, 2016 09:48 AM
spthomas
Jul 4, 2007 01:55 PM
jktiffin
Jul 20, 2006 09:24 PM
mtidwell
May 2, 2006 09:15 PM
Al
Jun 30, 2005 02:29 PM
