C70 T5 Misfire
Old Jun 9, 2016 | 12:51 PM
Scottyb's Avatar
Default C70 T5 Misfire
Hi, I'm new to this club and Volvo ownership but I need help
I just bought a Volvo c70 t5 GT 1999 with171000miles on the clock and the first 100miles were OK .
But I now have a misfire just of idle and lack of power , the engine warning light came on so I disconnected the battery to clear the warning light and run the car again the warning light stays off but I still have lack of power and more importantly the misfire.
I connected a code reader and there are no active faults or stored faults.
I removed and checked all spark plugs and regapped all the plugs look new.
Air filter looks new and all turbo pipes all look OK.
Any help would be appreciated
Thanks
Scott
Old Jun 11, 2016 | 07:26 AM
MSGTUSMC's Avatar
Default Misfire
You need a different code reader. Most auto parts stores will read the codes for free.
Old Jun 11, 2016 | 02:55 PM
Scottyb's Avatar
Default mis fire
hi, took the car out today and the engine light came on so connected code reader and code p0302 cylinder 2 misfire, is likely to be a coil?
thanks
Scott.
Old Jun 11, 2016 | 09:16 PM
could be the coil or the connector. Easy test is to swap cylinder 2's coil with say 3 or 4 and see if the misfire moves to another cylinder. It could also be your fuel trim is slightly off (ie vacuum leak or intake tubing leak/dirty MAF/IACV/throttle body) but leave that for after swapping coils.
Old Jun 12, 2016 | 05:35 AM
tryingbe's Avatar
Do a compression test.
Old Jun 13, 2016 | 06:43 AM
MSGTUSMC's Avatar
Default Misfire
Check plugs!
Old Jun 19, 2016 | 05:27 PM
Scottyb's Avatar
Default Misfire
Hi, swapped number 2 coil with number 1 and now the misfire is number 1cylinder.
Will fit a new one tomorrow hopefully that will cure the misfire.
I will let you know if it is cured.
Thanks
Scott
Old Jul 6, 2016 | 04:01 PM
Scottyb's Avatar
Default Misfire
Hi, fitted the new coil and all OK now
trashcanman
Mar 11, 2014 06:13 PM
ABVO850
Feb 9, 2013 07:44 PM
GoVolvoParts
Nov 29, 2012 08:46 AM
Almyar
Jul 29, 2011 07:22 PM
