cannot reset SERVICE light
Old Apr 29, 2013 | 01:11 PM
liweih21's Avatar
Default cannot reset SERVICE light
Hi, just got a 2000 C70, it has some wear and tear and some unknowns, first problem:
I can't reset the SERVICE light (no check engine light), I used the instruction and will trying to reset the light I see it blinks no chime and still STAYS on.
problem? could I pass smog with that light on for 2 mins?
Old Apr 29, 2013 | 08:47 PM
damien360's Avatar
ido you take your finger off of the button as soon as the service light flashes. if you keep pressing the button, the light comes back on. if it still stays on even with releasing the button as soon and it starts blinking, you can go to the dealer and see if they can delete it using VIDA. and if it doesnt go off using vida its caused by an internal fault in the cluster and will need to be replaced.
Old Apr 30, 2013 | 02:36 AM
liweih21's Avatar
Default solved
apparently, you have to let go when the light flash right away, I tried about 5 times and finally paid when an experience tech did it and went away - I was amazed and yet felt extremely stupid.
Now another problem, I have intermittent BULB light goes on when I brake, I want to check for the rear right tail light and all the bulbs.... how do I do so?
Old Apr 30, 2013 | 04:45 AM
The service light should not cause a fail on an inspection.
To check tail and brake lights, back up towards a picture window line at a plaza or someplace like that.
akinsey
Jul 20, 2013 12:28 AM
maxx4072
Apr 28, 2005 10:34 AM
schmidtc
Feb 9, 2004 01:41 AM
bongo240
Oct 31, 2003 03:02 AM
