Check Engine Light not working!
Old Aug 10, 2009 | 07:11 PM
ckevg's Avatar
Default Check Engine Light not working!
Everything else that's supposed to come one when you first turn the key does. How hard is it to see if it's just the bulb? And if it isn't the bulb, what else could it be?Thanks!
FYI - It definitely doesn't work because I had a few things go wrong recently that should have triggered it. I believe it was messed with when I went back to have some work done that was promised to me by the dealership I bought it from. It wasn't a Volvo dealership by the way.
Thanks!
Old Aug 10, 2009 | 07:18 PM
I will bet the bulb is blown or missing.
Old Aug 10, 2009 | 07:56 PM
ckevg's Avatar
Does the whole dash or instrument panel have come out to access it?
Thanks for the reply!!!
Old Aug 10, 2009 | 07:58 PM
Just the top part of the dash needs to come off to get the speedo cluster out.
I think there is a post in the S70 section about doing it.
Old Sep 8, 2009 | 03:08 PM
ckevg's Avatar
It's missing! Shady!!!!
Old Sep 8, 2009 | 04:29 PM
ckevg's Avatar
Missing!
I posted this on another forum. Maybe you have some insight before I take to the dealership. Thanks!
"I've been out of town for a while, thanks for the replies. I didn't drive the car, but now it's acting really strange. It's vibrating really bad, missing/fluttering(??) and the exhaust smoke has changed from black to blueish gray. BTW the CEL bulb was missing! I guess it's time to call AAA and have it towed to a Volvo mechanic!!!!"
Old Sep 8, 2009 | 09:00 PM
Someone pulled it for the reason of selling quick.
Old Sep 11, 2009 | 03:37 AM
nagesh's Avatar
Default To make Engine Light not work
The dealer replaced the fuel pump, did a 24hour pressure test no problems. Drove til car was down to 1/2 tank, check engine came on again. This time there was rough idleing and it died. This happened three times before I could even put it into reverse. So, less than 5000 miles and in the shop yet again . My DH has a 10 yr old Lexus LS 400, 200,000 and has never had the engine light on.
dsl isp
plus size strapless bra
rob17san
Nov 13, 2019 11:50 AM
rspi
May 15, 2014 07:36 AM
dhvolvo
Mar 11, 2011 04:24 PM
BigAdam
Oct 21, 2008 10:01 AM
