Codes
Old Feb 1, 2011 | 10:52 AM
SolidHit's Avatar
Default Codes
My wife's 2000 C70 has been giving her problems for the past year. Sometimes the speedometer works, sometimes it doesn't. Sometimes the car will buck while driving and other times it's perfect.
Our mechanic found the following codes:
P1633
P1618
P0722
Any ideas?
Old Feb 1, 2011 | 08:14 PM
mkc70's Avatar
P1633
P1618
P0722
Any ideas?
Rebuild or replace your ABS module, common problem for Volvo models of that era.
Old Feb 2, 2011 | 05:39 AM
SolidHit's Avatar
Thank you. Research says that should take care of codes 1633 and 0722 but what about 1618?
Old Feb 23, 2011 | 11:20 AM
daivolvo's Avatar
Default code
here is the problem for code 1618
Diagnostic trouble code (DTC) in another control module
P1618ECM-530DDiagnostic trouble code (DTC) in another control moduleP1618ECM-530DDiagnostic trouble code (DTC) in another control module
Old Feb 23, 2011 | 05:02 PM
mkc70's Avatar
Lightbulb
Weird.
Old Feb 24, 2011 | 07:33 AM
SolidHit's Avatar
I sent the ABS module off to CA for a rebuild and got it back on Friday. Got it installed on Monday and the car has been running perfectly since then. It's possible that the questionable code could have been a flyer since there are a lot of other electronics that run through the ABS.
gabyman97596
May 14, 2007 09:52 PM
TBoone
Aug 8, 2006 12:52 AM
cranky
Aug 5, 2005 09:46 PM
pitar
Apr 2, 2005 11:37 PM
