Coolant leak
Old Sep 1, 2006 | 09:35 AM
snulma1's Avatar
Default Coolant leak
Well once I solve one problem, another surfaces! Doesn't it always seem that way.
Well I seem to have a small to moderate size leak. But not real sure of where its coming from. It is pooling on the floor in front of my front passenger wheel. But because of the shield underneath I can't see where its coming from. I am going through coolant and water at about a gallon in a month and a half.
Has anyone had a similar leak, and know how and where to check? Thanks
Old Sep 1, 2006 | 08:58 PM
Default RE: Coolant leak
Remove the Cover and I will bet the Radiator is leaking.
Old Sep 2, 2006 | 11:48 PM
snulma1's Avatar
How do I remove the cover? And if it is the radiator, how bad of a bill am I in for?
Old Sep 3, 2006 | 12:34 AM
While under the car there is a screw on each end of the cover. It is a 10mm screw.
If it is the Radiator it will be a Pretty big Bill.
Like $250.00 for the Radiator and like 2 to 3 hours labor.
I would say maybe Ballpark like $450.00 or more.
Old Sep 6, 2006 | 10:44 PM
maddox's Avatar
I had a similar problem with my 2000 C70. Another place to check is look under the expansion tank at the hose connection. Mine was slight and was three fold. There was a small crack in the tank, the hose ended up being bad, and the clamp was egg shaped and thus wouldn't clamp well. Sealed the tank, replaced the hose and replaced the clamp.
Just another place to look.
Guy
no1pony
Sep 3, 2011 06:45 AM
aru5016
Jun 19, 2011 12:26 AM
cmayo313
Mar 18, 2011 12:09 PM
Ahmed
Aug 30, 2009 01:58 PM
timk
Nov 16, 2007 08:33 PM
