driver seat
Old Aug 21, 2007 | 02:28 PM
c70turbogt's Avatar
Default driver seat
Hey guys..... a little help. My seat wont lean up or down......the tilt, forward and backward movement all work....but i cant make the seat lay back or lean forward....
thanks,
Old Aug 22, 2007 | 01:58 PM
c70turbogt's Avatar
Default RE: driver seat
Can someone please help me with the above problem? Thansk
Old Aug 22, 2007 | 10:48 PM
Shaun Oriold1's Avatar
If I'm not mistaken this has been covered multiple times. So speand a few minutes searching, and you might find what you're looking for. People generally dont like to re type stuff over and over again.
If I were you. I would check to make sure that all the wires are intact.. Maybe one got cut ( ripped) by mistake. Then check the plastic gear that actually moves the stuff. It could also be the contacts on the switch itself.
Saying something just does not work, and expecting people to be able to diagnose it is a tall order.
Good luck.
S.
Old Aug 23, 2007 | 09:15 AM
99VolvoV70's Avatar
ORIGINAL: Shaun Oriold1
I would say, "Saying something just does not work, and expecting people to be able to diagnose it is a tall order when Tech is out of town.
By the way, I have a similar problem with my driver's seat on my V70 - it won't slide forward. Luckily, there's a preset button that is far enough forward for my wife so we can get by for now. Some day I'd like to go in and figure out what's wrong with that. I have seen one or two posts on this earlier and I think either Tech, JimKW or JPN responded with some insightful thoughts although I can't remember what they said at this time.
Here are a couple of threads that I found that might help you:
https://volvoforums.com/m_33215/tm.htm
https://volvoforums.com/m_4852/tm.htm
https://volvoforums.com/m_28932/tm.htm
https://volvoforums.com/m_44566/tm.htm
(Hopefully these will help me later when I look into my problem so I don't have to search everywhere again.)
redheadskier
Feb 1, 2010 11:55 AM
guptash
Apr 1, 2007 12:17 AM
kathoderayblue
Oct 29, 2005 10:16 PM
unbuagable
Oct 4, 2005 08:59 PM
summervi
Aug 28, 2005 11:14 AM
