ECM-9A0B : ecu internal fault
Old Sep 17, 2024 | 10:38 PM
titus's Avatar
Default ECM-9A0B : ecu internal fault
Does anyone know something about this code?
My 2011 C70 is in limb mode and will not rev above 3000. The only code stored is ECM-9A0B which is an ecu internal fault code.
https://www.dtcdecode.com/Volvo/ECM-9A0B
I have replaced the ecu once already to see if it would fix the issue and nothing changed. I thought I might have a wiring issue causing the ecu to fail but I do not think that is the case. The car runs great when I reset the code but will not idle great once it triggers the code.
rabee7878
Dec 16, 2020 03:57 PM
bit_eimer
Jun 11, 2017 10:09 PM
VolvoBug
Oct 13, 2014 02:44 PM
johnnyocc
Mar 6, 2010 09:05 PM
RED MOFO
Dec 22, 2009 05:11 AM
