Engine System Service Required and AC compressor
Old Nov 22, 2021 | 09:28 AM
JBrouss105's Avatar
Default Engine System Service Required and AC compressor
A few months ago I got the Engine System Service Required message for about a week and then it went away. It came back yesterday and it seemed to coincide with the AC Compressor going out for a little while. The AC compressor reengaged after about 2 minutes. Could these be related and does anyone have any insight on this? I'm hoping the ESS message just goes away again but the AC going out is a problem. Thanks.
Old Nov 22, 2021 | 01:51 PM
Engine system service means there is a self diagnostic code stored - use a compatible scan tool to find out what code/s are stored and go from there.
AC- what exactly happens? It stops being cold? A common problem in warmer weather is the clutch gap becomes too large from wear and the clutch will stop engaging after it gets hot.
Old Nov 22, 2021 | 01:54 PM
JBrouss105's Avatar
Yes, it stops being cold for a few minutes. I had the compressor replaced 2 years ago so I don’t think it’s wear and tear.
Old Nov 22, 2021 | 02:34 PM
Then several other things can cause that. Evaporator temp sensor, and outside air temp sensor can shut the compressor off if sending the wrong value. Scan with a compatible scan tool and you should be able to check what signals are being sent. Also the CCM can store codes also.
Newport_j
May 10, 2019 10:39 AM
rajib
May 3, 2016 06:24 AM
rspi
Jun 27, 2013 05:33 PM
FisrtVolvoEver
Aug 16, 2012 07:27 AM
abigweasel
Aug 2, 2011 10:54 AM
