Front Brake problems 2011 C 70
Old Apr 22, 2014 | 02:38 PM
Roger1689's Avatar
Default Front Brake problems 2011 C 70
Yesterday when I braked at 65 mph. I got a shudder in the steering wheel, like you would get when you have a warped rotor. This continued every time I braked, then when going slow on a back road, I heard a metallic noise kind of tinny sounding, the next time I had to brake the shudder was gone. Has anyone experienced this or have a idea what is wrong.
Thanks for any help
Roger
Old Apr 23, 2014 | 12:29 PM
HoopyFrood's Avatar
If I were you I'd be pulling the wheels and checking things out. You've could have broken a bolt that insinuated itself between the pad and rotor and finally worked it's way out. OTOH you could have picked up a rock that did the same thing.
However brakes are nothing to wonder about. Pull the wheels and have a quick look and make sure all the necessary parts are still there. Better safe than sorry.
Good luck.
Old Apr 24, 2014 | 09:53 AM
MSGTUSMC's Avatar
Check the stone guard at the bottom of you disc brake rotors, might be bent allowing something to get between rotor and guard.
michaeltroy
Dec 27, 2014 03:53 AM
michaeltroy
Dec 17, 2014 07:12 AM
arimendoza
Nov 13, 2014 03:13 AM
discodave
Jan 18, 2013 03:46 PM
