Fuel filter help on 1998 c70
Old Feb 19, 2012 | 01:16 PM
TONY12340's Avatar
Default Fuel filter help on 1998 c70
Hi everyone
i did full sevice on my 1998 c70 today but i couldnt manage to get to do the fuel filter
can anyone suggest the correct procedure as to how to remove this from the car?
The manual says there is a pressure release valve similar to a tyre valve but when i had a look it doesnt seem to look like that and cant see a way of unscrewing the cap?
Any uggestions will be much appreciated
thnks
Old Feb 20, 2012 | 06:21 AM
MSGTUSMC's Avatar
Did mine recently. Everything is covered in undercoating. The cap comes off just like a tire valve. Press to release pressure. The filter is held in by 3 bolts in a bracket. 2 longer bolts easy to put back in, third short bolt goes thru 3 pieces were clamp holds filter in place, difficult to replace, I got a 1/2 inch longer bolt, made it easier. My filter was original equipment. I think all bolts were 10mm. I re-coated evrything after replacement of filter.
1998 Volvo C70 2.3 HPT Coupe Auto 37k miles
Old Feb 21, 2012 | 03:38 AM
TONY12340's Avatar
Hi thanks for your reply
I noticed the coating thanks for clearing that up
How do the pipes pull off the filter? Is it just a case of pulling off??
kyace
1998-2000 model year V70
Aug 10, 2012 09:02 AM
rspi
Dec 15, 2010 11:27 PM
musafir
Jun 16, 2009 02:11 PM
ICE
Mar 10, 2009 08:35 AM
DaveV70
Apr 23, 2007 09:27 AM
