Help - C-70 doesn't know door is closed
Old Feb 26, 2008 | 04:42 PM
dhpcb's Avatar
Default Help - C-70 doesn't know door is closed
My 1999 C-70 seems to think the driver's door is not closed. I had the problem intermittently for
some time and had to keep opening and closing the door until it quit. Now the problem has gotten
to where it is constant. The only dealer is an hour away and I would like to try to fix it myself. Has
anyone experienced this problem before? Thanks in advance for any advice.
Old Feb 26, 2008 | 07:45 PM
Default RE: Help - C-70 doesn't know door is closed
Sorry to say but the door latch assembly is bad.
Other bad part is that will be be expensive to replace as well.
The entire window assembly will have to come out to replace it.
Old Feb 28, 2008 | 03:00 PM
dhpcb's Avatar
Thanks Tech, is this a dealer only issue or can a local import shop fix it?
Old Feb 28, 2008 | 06:56 PM
Some will work on them and others won't.
The Dealer will be about 4 hours labor plus the price of the part.
Old Mar 3, 2008 | 08:42 AM
dhpcb's Avatar
Thanks for your help.
Old Mar 3, 2008 | 04:30 PM
reg's Avatar
reg
Is there a 'wire' that can be snipped to defeat "the bad part"?
Old Mar 3, 2008 | 07:03 PM
Only it the lock assembly was removed. Which after that much labor you would want to replace anyway.
Flow313
Nov 26, 2014 08:09 PM
Simtech
Jan 31, 2012 07:32 AM
oreng
Jun 4, 2010 05:34 PM
Shaun Oriold1
Mar 16, 2008 06:54 AM
mynauticaldog
Oct 11, 2007 08:45 AM
