Help !!!Radio SC-802 problem
Old Dec 22, 2021 | 06:39 AM
Doncarlos's Avatar
Default Help !!!Radio SC-802 problem
Hello from Portugal.
Somebody can help me,my rádio sc802 says OFF why???
I have change the motor and now only apears in the board OFF , don’t apears to put the code.
What can i do ?
Thank’s
Old Dec 22, 2021 | 10:51 AM
What can i do ?
The radio shows off because the wrong code was put in three times.
1. Give the radio serial number, part number (off the top of the radio) and model (sc802) to a Volvo dealership. With that info they can give you the right code by finding it in their database.
2. "Reset" the radio. Turn the key to the accessory position. wipers/light/ac fan/radio - all have power. Turn wipers/lights/ac system/etc off. Leave radio on and key in accessory position. The battery will be fine if you have everything except the radio off. Come back 2 hours later - radio will show "COD" and be ready for the correct code input.
3. Put in the correct code. If it does not work - it's not the right code. If you try it 2 more times the radio will lock and show OFF.
Seppe Scheiris
Dec 9, 2020 11:52 AM
technoreef
May 17, 2009 10:58 PM
hxc
Aug 22, 2008 01:36 PM
xkennx
Dec 13, 2006 03:10 PM
naxitrallike
Sep 29, 2006 05:38 PM
