intermittent high-pitched "whistle"
Old Jun 11, 2016 | 10:58 AM
hemismith's Avatar
Default intermittent high-pitched "whistle"
I'm suddenly occasionally getting an intermittent short high-pitched whistle, seems to be related to my my a/c, but I even get a little one after the car turns off. Anyone else experience this?
Old Jun 11, 2016 | 12:03 PM
if it changes pitch as you turn off/on the AC, I'd suspect one of the serpentine belt idlers or perhaps the AC compressor clutch. You'd have to remove the serpentine belt and feel the idlers to check.
Old Jun 12, 2016 | 07:53 PM
hemismith's Avatar
Thanks. I actually get a little of the same sound after I turn off the car completely, and it's intermittent enough that I'm pretty sure it's not related to the under the hood parts. It seems like it's caused by leaking air somewhere, and it only happens when it's really hot.
Old Jun 12, 2016 | 09:05 PM
are you losing any coolant? I'd suspect it cool be associated to the vacuum pump/booster. Next time you hear the sound with the engine off, try pumping the brakes to see if it changes anything.
Old Jun 13, 2016 | 06:51 AM
MSGTUSMC's Avatar
Remove and tighten coolant tank cap, ensure coolant is right color and topped off. Check thermostat area for leak or loose hose cracked housing. Test thermostat.
Old Jun 14, 2016 | 11:55 PM
hemismith's Avatar
Thanks everyone, I'll take a look at those things.
Old Jun 29, 2016 | 11:21 PM
hemismith's Avatar
So it turned out to be the a/c thermal expansion valve.
bigc55
Sep 20, 2015 11:53 PM
arhood
Oct 27, 2009 02:17 AM
Bruce Wayne
Apr 18, 2009 08:20 AM
cetaphil
Mar 23, 2009 08:27 PM
