mass airflow sensor
Hey guys. It has been a while. I need some advice. My car wont start up. The engine cranks but it does not sustain. The computer indicates a mass flow sensor problem. Any advice?
thanks,
akg
thanks,
akg
http://www.fcpgroton.com/product-exe...category_id/10
be advised that your fuel mileage will be affected and I am sure you will start 'throwing' additional codes. replace the MAF ASAP. CRC makes a product that 'cleans' the MAF although I doubt it would bring life back to your present MAF. It is a good product to prophylactically clean your MAF annually.
r
r
hey....
I had my dad pull the maf out as i am out of the country. It still didnt start up. Do you think it is the Electronic throttle control module? If so is it still covered under warranty....my car is a 99.....can someone use the vin to check for me?
Yeah I agree. You should be replacing the mass air flow sensor immediately. I had a similar problem before and I did not replace it for about 3 months then there was some knocking, pinging, stalling and shuddering of the car.. really bad..
