Microswitch on drivers seat
Old Jan 6, 2010 | 10:45 AM
tmc1874's Avatar
Default Microswitch on drivers seat
Does anyone know how to replace the spring on the microswitch for the seat? It seems to have popped off and now I have to push and hold a lever in the crack of the seat for the power adjustments to work.
Thanks
Old Jan 6, 2010 | 08:33 PM
Usually the plastic that the spring holds on breaks. There was a tech note which I do not have handy showed to drill a hole and install a screw to hold the spring.
Old Jan 7, 2010 | 08:19 PM
dphilips75's Avatar
Default Microswitch
This seems to be a common problem and has been discussed in previous posts if you do a search. I have the same issue with both my seats and will be looking into repairing them in the near future.
Old Jan 7, 2010 | 09:37 PM
mkc70's Avatar
Should be able to use a small piece of wire or a cable tie to make the switch work again. Peel back the leather and take a look, takes a few minutes to get it working.
vipul_vips
Sep 21, 2010 05:04 PM
elbert
Aug 20, 2006 07:55 PM
igtc
Mar 9, 2006 10:45 PM
floryed
Jul 6, 2005 07:58 PM
Micks Volvo
Jun 5, 2005 11:25 AM
