multiple electical lights, problems
Old Jun 11, 2007 | 10:56 PM
maddox's Avatar
Default multiple electical lights, problems
I havestrange things happeningso one maybe someone can point me in the right direction with avoiding the dealer.
My problem is sometimes in the last few days on my 2000 VolvoC70 convertible (Automatic)I will start the car and immediately I have:
1) The "brake" light and the "ABS" stay on .
2) Thespeedometer and odometer do not work
3) When I pull out from a stopping position it is like I am in "winter mode" but it really isn't.
4) The cruise control does not work.
5) and a couple of times the transmission arrow has been flashing.
The drivability of the car is fine. And I have checked everything. After a few minutes all the lights and everything works fine then the Check Engine light comes on. I could stop and turn it off and restart and this sometimes resets everything.
I pulled the codes and turned the check engine light off but same thing happened 1/2 day later.
The codes were:
1) PO722 - Output speed sensor curcuit no signal
2) P1618 - Manfacturer Control, auxilary inputs and outputs
Please someone point me in the right direction and tell me what to do.
Thanks in advance,
Guy
I can stop and turn
Old Jun 12, 2007 | 05:43 PM
Default RE: multiple electical lights, problems
The ABS module is bad. You can get it rebuilt here.
http://home.earthlink.net/~vicrocha/...vo_V70_ABS.htm
Old Jun 13, 2007 | 10:58 PM
maddox's Avatar
Tech,
How sure are you that repairing the ABS module will erase all my describedsymptoms? I have had the ABS module in my 98 S70 and it took care of the tracs and ABS lights and the functionality of both but I didn't have any other symptoms.
Please advise.
Thanks, Guy
Old Jun 14, 2007 | 05:44 PM
The 2000 is a networked car.
The ABS controls the speedo VIA Network.
Old Jun 17, 2007 | 11:51 PM
maddox's Avatar
Thanks Tech.
Old Jul 6, 2007 | 10:15 PM
maddox's Avatar
Repair of the ABS control took care of the problem.
Thanks Tech.
lotusing
Feb 7, 2015 08:06 PM
c70possessed
Oct 15, 2012 05:33 PM
dvfosho6
Mar 18, 2011 10:37 PM
jeff
Jul 21, 2006 01:53 AM
ludeless
Dec 13, 2005 01:37 AM
