What is this electical connector for?
Old Dec 9, 2005 | 05:27 PM
ludeless's Avatar
Default What is this electical connector for?
I noticed that i have an electrical connector near the battery that isn't plugged into anything. I have no idea what it is but have some pics of it.
Anyone what it's for and if it should be plugged into something?
[IMG]local://upfiles/2134/4A831CE5FF6A4461BF4CF63E37D10CB4.jpg[/IMG]
[IMG]local://upfiles/2134/1840056475D44A37BEEFABA0895AF97B.jpg[/IMG]
[IMG]local://upfiles/2134/14804A3C59EF4078A65704B7F9DE9CF1.jpg[/IMG]
Old Dec 9, 2005 | 08:55 PM
Default RE: What is this electical connector for?
Look under the battery tray and make sure the Cruise Control motor has a plug in it.
Old Dec 10, 2005 | 02:58 PM
reg's Avatar
reg
That sure doesn't look like a "factory" connector! Perhaps a prior owner was driving a radio amp or other 'add-on' accessory. When that individual sold his Volvo, most likely he disconnected the accessory and took it with him.
Reg
Old Dec 10, 2005 | 03:02 PM
That is a factory plug. Remember he has a 1995. there is alot of plugs on that car that look similiar to that one.
Old Dec 10, 2005 | 03:15 PM
ludeless's Avatar
Good timing! I was just going to post a 'why doesn't my cruise control work' question. It hasn't worked since i got the car. I was trying to think of something to fix today...looks like i've got something to do now.
Thanks
Old Dec 10, 2005 | 03:29 PM
Let us know how it goes. The cruise motor screws to the bottom of the battery tray. You might be able to see if from underneath.
Instead of removing the battery and battery tray.
Old Dec 11, 2005 | 02:52 PM
ludeless's Avatar
Yep, that was it. Very easy fix and i have my cruise control back now
Thanks Tech!
Old Dec 11, 2005 | 04:38 PM
No problem glad I could help.
Old Dec 11, 2005 | 04:39 PM
Old Dec 13, 2005 | 01:02 AM
reg's Avatar
reg
Volvo must not have been using the 'water tight' connectors back then as they use now. I'll bet you used to service a ton of corrosion issues when you worked on them!
Reg.
ORIGINAL: tech
Old Dec 13, 2005 | 01:37 AM
They actually work pretty good. The rubber around the connector would fall apart before the corrosion issues came about. They used them for the most part till 1998 on the S90's for the coil pack plugs.
lotusing
Feb 7, 2015 08:06 PM
jasstrom
Dec 10, 2013 03:41 PM
c70possessed
Oct 15, 2012 05:33 PM
dvfosho6
Mar 18, 2011 10:37 PM
maddox
Jul 6, 2007 10:15 PM
