OIL LEAK OR ???????
Old Jan 31, 2006 | 01:04 PM
mossop's Avatar
Default OIL LEAK OR ???????
ok heres the story..
August i had the big 90k service cambelts etc
since then i have had an op on my shoulder and have only covered 2000 mls
since it was such a pitifull mileage i hadnt checked the oil ooops
checked it today and it was only just marking the dipstick.
topped it up with 2 3/4 lts of helix.
now the problem is i need to know what happened to the oil
had the car up in the air to see the tell tale signs and couldn't see much tho [sm=dontgetit.gif]
cleaned around the filter had alook up the engine to see the turbo etc and nothing visible.
the only oil i found was on the rh side wishbone area but that seemed to be more like ps steering oil.
any ideas i read about the turbo oil pipe orings leaking but i found thes (the ones that go into the block) and they seemed all ok
have taken the air filter box off to get a better view of that part of the engine and agian all seemd fine the only thing i can think of is that when it was serviced the didint put the oil in or all of the oil?
any help or input would be greatly apreciated as i am scratching thru my head here!!!
cheers in anticipation
Mossop
Old Jan 31, 2006 | 09:21 PM
Default RE: OIL LEAK OR ???????
Most likely it burned some of it. Did you check it after they serviced it to see where it was on the dipstick?
Maybe they were a little short as well.
ROBLU540
Feb 20, 2009 07:59 PM
mkelly85
Jan 31, 2008 02:05 AM
pleonard
Jan 7, 2008 06:12 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
