P0340 & P0365 after starting
Old Feb 11, 2015 | 08:22 AM
stevenlee's Avatar
Default P0340 & P0365 after starting
I start the car it fires right up, then I shut it off and it just cranks, sometimes it will start eventually, igf I clear the code it fires right up again with a pending p0340 and p0365 which goes current when I try to restart
I checked the timing by taking the crank pulley off and checking the mark down on the crank gear and the oil pump housing and the two marks on the crankshaft and cover, spot on, I even put on a new belt and tensioner
is there some wiring I should check? could this be caused by the cam adjust solenoids?
some help would be greatly appreciated
thank you
Old Feb 14, 2015 | 12:30 PM
stevenlee's Avatar
does anyone know where I can find a wiring diagram so I can test the wiring?
thank you
(also any other suggestions?)
Old Feb 15, 2015 | 03:10 AM
MSGTUSMC's Avatar
Replace both cam position sensors. There is a kit to replace both cams. Zero tolerance engine if problem continues, new engine or rebuilt head !
Old May 25, 2021 | 07:24 AM
moojos's Avatar
thank you
hi there, i have the exact problem you have been describing, did you find the fix? if so please let me know as i am pulling my hair out.
Old Oct 31, 2021 | 11:23 AM
Sophenco's Avatar
Default Urgent
Please where is the cam position sensor located on XC90 2005. I have the code p0340
Old Oct 31, 2021 | 12:16 PM
To answer your question the cam position sensor is mounted on the end of the cam/s. But usually it's not a bad sensor - it's the cam timing is very slightly off - if you don't get the VVT/cam timing adjusted perfectly you will get a cam position sensor code. Not meaning the sensor is bad - it means the cam is in the wrong place at the wrong time.
Old Nov 2, 2021 | 01:04 AM
Sophenco's Avatar
Thank you for your response. I know next to nothing about cars. I wish I could get a pictorial description of the CPS location. I have tried googling but it's coming up with different locations.
m3rd
Jun 24, 2017 05:00 PM
s40dad
Jun 14, 2013 10:34 AM
silencecom
Feb 18, 2010 10:12 PM
DanC
Jul 29, 2008 04:43 PM
ludeless
Jun 22, 2008 08:39 PM
