P0507 and P2187 code help needed
Old Jan 6, 2022 | 03:28 PM
Moonk9's Avatar
Default P0507 and P2187 code help needed
Hi all,
Hoping you can provide some guidance.
I own a 2011 C70. Check engine light came on so I popped in my Carista and got these codes.
P0507 - idle air system rpm higher than expected.
P2187 - system to lean at idle bank 1
I am getting the “squeaky fan belt” sound which goes away when I pull the oil dipstick.
Thoughts?
Old Jan 6, 2022 | 04:29 PM
That's the common PCV failure. The squeal is un-metered air sucking past oil seals, like the noise when you slowly let air out of a balloon. Pulling the dipstick allows air in another way. Codes are created from the un-metered air making things lean. The pcv valve is part of the oil filter housing - I have heard the pcv portion might be available on the aftermarket - avoiding replacement of the entire oil filter housing - but I've never done it that way. #31338685
JBrouss105
Sep 29, 2021 08:56 AM
yoyoman
Jan 30, 2021 10:19 PM
kippster41493
1998-2000 model year V70
Feb 12, 2014 02:47 PM
sporky
Apr 5, 2011 03:22 PM
Typhoon
Jan 13, 2008 08:34 AM
