Parking sensors
Old Aug 23, 2009 | 03:20 PM
biteydog's Avatar
Default Parking sensors
I have just got a parking sensor kit. To fit it involves drilling 4 22mm holes in the rear bumber. Has anyone done this before?
What I need to know is the best place to drill the holes to make sure that there is about 25mm clearance behind the sensors.
I don't want to be doing this twice!
Old Aug 31, 2009 | 02:57 PM
mkc70's Avatar
Your local dealer could do the install if you want to pass. The link has some nice pictures to give you an idea of where the sensors should be located if you want to have a go at it, good luck.
http://www.cardomain.com/ride/3204914
Old Sep 4, 2009 | 11:18 AM
reg's Avatar
reg
I installed a kit such as what you describe, in my old c70. There is plenty of room (clearance) to install the four units.............make sure the two outside ones are closer to the corners of the vehicle. I mounted the 'horn' under the drivers seat by velcro to the carpet.
r.
Mendies
Mar 27, 2009 06:25 PM
Old850
Oct 26, 2008 08:27 PM
talrejaameet
Sep 20, 2008 09:11 AM
speedster77
May 31, 2007 08:34 AM
Barrythecat
Sep 9, 2005 02:59 PM
