question on code
Old Dec 21, 2008 | 08:14 PM
c70turbogt's Avatar
Default question on code
I had my check engine light come on . It pulled the code: "P0014 Exhaust Camshaft Position Timiing Over-advanced bank (1)". What does this mean? Is it an easy fix?
thanks!
akg
Old Dec 21, 2008 | 10:26 PM
Default RE: question on code
Did you just do a timing belt?
Any work done lately?
Old Dec 22, 2008 | 10:45 PM
c70turbogt's Avatar
no work done lately....not timing belt....valves tick a little...dont know if they are sticking or need to be adjusted....then 3 weeks later check engine light came on......pulled the above code off it... thanks
Old Dec 22, 2008 | 10:59 PM
There is a camshaft reset valve that mounts to the cam cover over the exhaust cam. That valve might be sticking/bad.
Old Dec 24, 2008 | 02:19 PM
lilkarencita's Avatar
Hey, let me know how you get that code fixed. i was just at my mechanic and the obd pulled up code P0014 for the camshaft timing over advanced.
the only work i've done lately is my abs control unit. just got it replaced when we reset all codes, but P0014 never cleared.
Old Dec 24, 2008 | 07:20 PM
c70turbogt's Avatar
will do...am scheduled to take it in monday.....as soon as i know whats up ill post
Old Jan 12, 2009 | 06:09 PM
c70turbogt's Avatar
as requested I am posting what the problem was on my above post from that code. It ended up being a variable valve timing hub and a selenoid.....it cost me about 600 dollars.....was i taken for a ride guys? plus had my timing belt done with a timing belt kit for about 500.....hows that too?
thanks guys!
Old Jan 13, 2009 | 07:32 AM
You got off cheap!!
91shelby
Feb 4, 2011 08:24 PM
Elsid
Sep 9, 2010 08:42 AM
badmonkey
Jul 28, 2008 09:15 PM
gzh
Mar 21, 2007 09:29 PM
skatermattc2
Feb 1, 2006 04:15 PM
