PULLED CODE PO455
Old Jan 13, 2009 | 02:53 PM
eldonixon's Avatar
Default PULLED CODE PO455
I recently purchased a 2001 C70 Convertible with 115k, much to the chagrin of my wife. The first time she drove it, the check engine light came on. Really put me in good stead. I pulled the code P0455-EVAP EMISS CONTROL LEAK (LARGE). Any ideas.
Thanks
Old Jan 13, 2009 | 04:42 PM
Default RE: PULLED CODE PO455
Either the gas cap is/was loose or there is a fault somewhere in the system.
Old Jan 13, 2009 | 04:56 PM
eldonixon's Avatar
I tightened the gas capnot that it seemed loose, but the light did not go out. I know my Benz will turn the check engine light out if the cap was a fault. I'm not as familiar with the Volvo. I just reset the light today, so I can see if it reappears. If it does and the problem is not the cap, where should I start looking? I tried searching but didn't find anything.
Thanks for the reply.
By the way, the forum has already been helpful in explaining a few other quirks.
Old Jan 13, 2009 | 05:15 PM
If the cap is not the fault you will need to start checking the hoses from under the hood on the evap valve to the tank.
The evap valve is located on the cooling fan under the hood.
There is a hose going from the intake to the valve then another one going back to the fuel tank.
Old Jan 13, 2009 | 11:04 PM
eldonixon's Avatar
Thanks for the info. Made the 30 mile trip home without the light. I'll keep my fingers crossed.
OverTheTop
May 6, 2006 09:50 AM
fishbulb95
Apr 5, 2006 12:48 AM
my_d3c3mb3r
Mar 24, 2006 09:30 PM
akbar
Feb 20, 2006 10:14 PM
colgate41
Oct 26, 2005 08:28 PM
