quick question...
Old Jan 30, 2007 | 05:49 AM
TheSaint's Avatar
Default quick question...
Searched the forum but did not find a suitable answer. A quick question, is the hand brake adjusted at the handle/console or at the rear brake disk? Does it use the disk or does it have it's own shoe pads in the hub? Ok... so that was two quick questions. [sm=chattypair.gif]
Old Jan 30, 2007 | 10:31 AM
reg's Avatar
reg
Default RE: quick question...
There is a set of shoes in the rear disc. There is an opening on the rear rotor that you make the first adjustment thru. Expand the shoes until the wheel does not turn and then back it off 4 to 5 notches. Then the final adjustment is made at the hand brake assembly. At the rear of the console there is a cover that must be removed and then it is simply a matter of tightening the nut at the end of the brake handle. Supposedly the 'full braking' mode should be when the handle is raised about five notches.
Reg
colgate41
Oct 12, 2006 09:41 PM
tomservo
May 16, 2005 12:36 AM
eurochick
May 10, 2005 01:27 AM
jaz
May 7, 2005 12:59 AM
volvobacon
Apr 17, 2005 01:24 AM
