Red Warning symbol show as I drive 2008 C70 "Stop safely to avoid damage"
Old Sep 8, 2020 | 01:32 PM
k1s40's Avatar
Default Red Warning symbol show as I drive 2008 C70 "Stop safely to avoid damage"
After I replaced front struts that includes unplugging and re plugging sensors on front wheels, the red triangle warning symbol show and red message indicates:"Stop safely to avoid damage" with beeping sound.So I ran Vida, cleared all old errors and re ran, there is no error, no DTC, no engine code yellow light but the red warning stayed.Ran Vida again , this time selected transmission type AW50, there is an error code:
TCM-0192 Gear Selector Module(GSM) Faulty Signal, this error does turn on the red triangle warning but seem
unrelated to front Struts replacement.
I wonder how to clear the red triangle warning light as the beeping noise is annoying.Disconnected the battery for an hour to reset, after connecting it again the same warning show as I drive.
Old Sep 9, 2020 | 11:59 AM
code is going to reset as soon as you turn on the car, Did anything fall into the shifter blind recently? the code is saying the shifter's position sensor is not reporting for duty :-)
Old Sep 9, 2020 | 12:03 PM
k1s40's Avatar
The code does not disappear, as I drive.Red flashing warning Only show after car is moving.
Thank for the hint, it is possible something fallen into shifter, not an easy thing to open and look around.
If that be the case this flashing red warning and loud ding sound with message
is really excessive, gives impression that something major is about to break.
Opened the console (that is a lot of work on C70), it was the infamous shifter blind magnet that was broken lose, ordered a new shifter blind 8699465
Tony Martin
Aug 18, 2020 06:03 PM
keakar
Jul 29, 2019 03:33 PM
Volvo sue
Oct 26, 2017 07:46 PM
britcan
Oct 3, 2010 11:56 PM
dickwroe
Mar 28, 2006 08:57 PM
