Reset after accident?
Old Dec 1, 2008 | 04:28 PM
dpallen's Avatar
Default Reset after accident?
How do you reset the safety after an accident? I slid off the road and need to now the vehicle will not run down the road. I beleive there must be a fuel cut off safety that needs to be reset. How do I do that?
Additionally how do I reset the ROPS? That is less critical as I need to take it to the shop to aligh the vehicle and repair some other stuff.
Old Dec 2, 2008 | 07:18 AM
Default RE: Reset after accident?
Do you mean the car will not start?
Old Dec 2, 2008 | 07:54 AM
dpallen's Avatar
The car will start but not run for long. After my trip into the ditch it idled fine. After being pulled back onto the road it would start but would only run for a short while before stalling. I beleive that the retreival also set off the ROPS.
The owners manual does not say anything that I could find about a safety reset on the fuel cut off or the ROPS.
Old Dec 2, 2008 | 08:18 AM
Maybe something was damaged when it was being pulled back out. If the intercooler was cracked or broke then it would cause the problem you have. I would start there.
Old Dec 2, 2008 | 04:09 PM
reg's Avatar
reg
I don't believe that the C70 has a fuel 'cut off' safety switch. They are usually installed in the boot but I doubt that Volvo had such a device on the older C70's.
r.
Old Dec 4, 2008 | 04:46 PM
dpallen's Avatar
OK. That is more problematic then I hoped for. Would the cracked Intercooler not throw a service engine code?
Old Dec 4, 2008 | 05:29 PM
Some times it will throw a code other times it might not if it has not been driven alot.
dennisk
Nov 5, 2011 04:15 PM
Roden2007
Dec 16, 2010 07:17 AM
jdaniels30
Apr 30, 2010 03:11 PM
Kaybihiak
Dec 1, 2007 11:03 PM
EAS1
Jun 23, 2007 05:18 AM
