Reverse light wire?
Old Feb 1, 2020 | 10:27 AM
KBBN's Avatar
Default Reverse light wire?
I am attempting to install a backup camera. I need to tap into the reverse light wire. Can anyone please tell me what color that wire is? Also, I need to ground a second wire..is that black or do you recommend grounding elsewhere? Thank you
Old Feb 2, 2020 | 09:59 PM
lon888's Avatar
The reverse light wire is green with a black stripe. Black is the color of the ground around rear light area, but if were me, I'd choose any convenient metal area and loosen a screw or bolt and attach the ground wire there. good luck!
Old Feb 4, 2020 | 06:57 AM
KBBN's Avatar
Default Success
Thanks! It works now...couldn't find info on wires anywhere on line or in manual! TY
Old Feb 4, 2020 | 09:47 PM
lon888's Avatar
Glad it worked out for you. If you ever need any wiring diagrams just let me know. Cheers, LC
Old Apr 27, 2020 | 04:12 PM
Dshaw2020's Avatar
Hi I'm trying to find the reverse light wire. I am setting up a autovox wireless camera but its not working when I connected it to the green with a black stripe.. Not sure if its the connectors that came with the kit or if it's the wrong wire. Any suggestions would be appreciated. Thanks!
Psaboic
May 17, 2017 08:35 AM
240-FAN
Aug 9, 2014 11:40 AM
mtlndg
Jul 23, 2013 08:40 AM
mtlndg
Jul 23, 2013 08:15 AM
Tractors4u
Jul 8, 2008 05:29 PM
