Shudder under Acceleration
Old Aug 19, 2020 | 06:09 PM
wheelsport's Avatar
Default Shudder under Acceleration
I recently purchased an '08 C70. There was shuddering under acceleration so I replaced the spark plugs and checked the coil packs by disconnecting each one in turn. They all caused a drop in RPM. Then I replaced all the motor mounts and both axles. This cured most of the shudder problems but there is still a slight shudder under heavy acceleration. I'm at a loss as to why I still have problem. Could the torque converter be starting fail, weak coil packs, ect?
Old Aug 26, 2020 | 09:44 PM
Cees Klumper's Avatar
I have the same issue. After having eliminated the likely causes, the last thing for me to try is replacing the auto trans fluid as I've read reports of that being a possible cause. New oil and filter are sitting in my garage, waiting until I can get to it.
Old Aug 28, 2020 | 09:19 AM
wheelsport's Avatar
Thanks for giving me a possibility to check out.
loudog159
Jan 28, 2016 04:10 PM
jackbrady
Dec 29, 2008 09:52 PM
WiseOne
Sep 13, 2008 09:29 PM
frisbb
Oct 1, 2007 05:58 PM
frisbb
Oct 1, 2007 11:29 AM
