Something loose tapping when roof is closed
Buy some green 3M masking tape; the 3" wide, green type.
3M Scotch High Performance Masking Tape, 3 Inches x 60 Yards, Green https://a.co/d/1WkMRzW
- One strip of masking tape per drive, lay that strip on a particular portion of the seam areas first.
- Then to the canopy if you haven't found your source by then.
Good luck! Updates, please.
Don't tape the whole seam area, maybe try 2' increments. That way you've pinpointed the spot when you find it.
