things must do around 80k if car hasn't been serviced much
Old May 3, 2013 | 03:45 PM
liweih21's Avatar
Default things must do around 80k if car hasn't been serviced much
Hi, 2000 c70 lt, need some advice with things must do around 80k if car hasn't been serviced much.
doesn't seem any problems, no CEL, no Service, but from what I think, the original owner has a 85k contract, so they got rid of it to me now at 80k, so I don't know what was done at 60k.
any advice, I know the timing belt should be done soon.
Old May 4, 2013 | 02:48 AM
MSGTUSMC's Avatar
pg. 108 Maintenance schedule
2000
MAINTENANCE SCHEDULE
C70
For complete maintenance information, please refer to your
Warranty and Service Records Information Booklet.
    Maintenance Operationthousand miles 7.5 15 22.5 30 37.5 45 52.5 60 67.5 75 82.5 90 2 (thousand km) (12) (24) (36) (48) (60) (72) (84) (96) (108) (120) (132) (144) EMISSION SYSTEM MAINTENANCE Engine oil and filter 1 R R R R R R R R R R R R Engine drive belt (accessory belt) R Air cleaner filter R R R Spark plugs R R R Automatic transmission fluid I I I I I I Timing belt - all engines3 1) See section "Engine oil" for detailed information.
    NOTE: The oil should be changed at these intervals, after 750 hours of driving or after 12 months,
    whichever occurs first.
    2) For services beyond 90,000 miles (144,000 km), please refer to the Warranty and Service Records Information Booklet". 3) For proper functioning of the vehicle and its emission control systems, the timing belt and tensioner must be replaced every 105,000 miles (168,000 km).
    pg. 109 Maintenance schedule
    2000
    C70
      Maintenance Operationthousand miles 7.5 15 22.5 30 37.5 45 52.5 60 67.5 75 82.5 90 (thousand km) (12) (24) (36) (48) (60) (72) (84) (96) (108) (120) (132) (144) EMISSION SYSTEM MAINTENANCE Engine Fuel line filter1 PCV nipple (orifice)/hoses, clean I I Battery (check charge and electrolyte level) I I I I I I I I I I I I Brakes Inspect brake pads, replace components as necessary I I I I I I I I I I I Brake fluid level2 - check I I I I I I Steering/suspension Tires3, check pressure, wear and condition I I I I I I I I I I I I Check power steering fluid level I I I I I Body Power antenna (clean) L L L L L L Trunk/hood, hinges and latches L L L Cabin air filter (see page 111) R R R R R R
      1) Replace at 105,000 miles (168,000 km)
      2) Brake fluid should be changed at owner request every second year or 30,000 miles (48,000 km). The fluid should be replaced once a year or every 15,000 miles (24,000 km) when driving under extremely hard conditions (mountain driving, etc.).
      3) Rotate tires at owner request.
      The following items should be checked weekly by the driver (it takes only a few minutes):
      Engine oil level, brake fluid level, radiator coolant level, operation of all lights, horns, windshield wipers, tire pressure (all five tires), windshield washer fluid level
      The following should also be carried out at regular intervals: Washing (check all drain holes), polishing, cleaning
      Old May 4, 2013 | 02:50 AM
      MSGTUSMC's Avatar
      Default 2000 c70 maintenance schedule
      2000 VOLVO C70
      ijourneaux
      Dec 16, 2013 12:28 AM
      vasco
      Jun 27, 2013 07:43 PM
      Schaeffy
      Oct 24, 2012 05:22 PM
      kerrplunks
      Jun 7, 2010 11:10 PM
      skyman
      Apr 26, 2006 09:56 PM
