trouble removing vvt from cam
Old Oct 4, 2009 | 11:42 AM
ducksauce's Avatar
Default trouble removing vvt from cam
Hi, I hope someone can help me with this. I'm doing a head gasket on a 2000 c70 2.4. I was told I have to remove the VVT off the exhaust cam. I made a steel cam locking tool and was able to remove the torx 55 plug but, I cannot get the torx 55 bolt behind it to budge. I wouldn't think it is reversed thread but I figured I'd ask because I'm bending the cam tool. There is quite a bit of force being applied to it and it's not moving. Any suggestions? Thanks
Old Oct 4, 2009 | 04:34 PM
It is torqued pretty good. You need to put more pressure.
Did you mark the pulley good to the cam cover before trying to remove it?
If not do it now. It is a major pain in the A** to get setup if not marked before removing it.
Old Oct 15, 2009 | 07:07 PM
ducksauce's Avatar
Thanks, I finally got that bolt off. I had to heat treat my homemade tool to make it stronger.
Old Oct 15, 2009 | 08:07 PM
Glad you got it.
dkjauto
Aug 14, 2014 10:14 AM
Hopper
1998-2000 model year V70
Sep 15, 2012 10:48 PM
MrEd
Dec 16, 2010 07:33 PM
dean wolverton
Jun 6, 2010 08:44 PM
fixing4friend
Dec 3, 2006 11:21 PM
