windows/noise/1999
Old Nov 28, 2006 | 03:32 PM
fritzlovesmary's Avatar
Default windows/noise/1999
hi, we have a 1999 coupe and unfortuntely have the infamous windnoises as well. i found one post about it for a 2001 model and tech said that after you take off the panel you will see 2 bolts with torx - then you can try your luck with adjusting.
does the 1999 model have the same mechanism? i had the panels off already but couldn't see anything like that. maybe someone has a picture of a door without the panels off and the location of the mechanism pointed out.
thanks
fritz
Old Nov 29, 2006 | 08:45 PM
Default RE: windows/noise/1999
Sorry no pics here.
The screws are in the bottom of the door at the front and back.
There is usually a piece of foam over them. Usually one is round and the other is square.
Old Dec 1, 2006 | 11:29 PM
tech - thanks for your answer, i will check this out again in the next few days.
fritz
gnstuckey
Feb 13, 2019 07:04 AM
mjohnny
Mar 18, 2013 02:35 PM
rezology
Jun 13, 2010 10:42 PM
7antera
Jun 2, 2008 08:00 AM
CHong4528
Jan 25, 2008 01:17 PM
