99 C70 DEFROSTER PROBLEM
Old Dec 4, 2006 | 09:57 AM
gasman59's Avatar
Default 99 C70 DEFROSTER PROBLEM
Hello all (especially Tech):
The air flow from my defrosters seems weak. Even on max fan, if I switch to the cabin vents air pours out.
Selecting the foot/floor vents only or defroster only it seems very weak and you can hear the air pressure in the system change, or build up.
Since winter is upon us, I need good defroster capability.
My questions:
Is the air flow control(s) vacuum or electric? (I am used to the vacuum modules on most cars but I do not know if Volvo uses these)
How does one access the defroster control module/motor to inspect/replace it?
Any adjustments?
Thanks,
Ron Y
1999 C70 Convertable
Old Dec 4, 2006 | 08:20 PM
Default RE: 99 C70 DEFROSTER PROBLEM
It is an electric motor.
It might need to be recalibrated. (Dealer only)
They are located in the air box under the dash on the drivers side.
I forget which one is for the Defrost though. There should be 3 there.
Old Dec 4, 2006 | 11:52 PM
gasman59's Avatar
Thanks Tech. I will call my dealer.
How was your trip back from NJ a few months ago? Too bad we could not connect. I think I left my email after you were on the way up.
Thnaks again,
Ron
Old Dec 5, 2006 | 12:40 AM
The trip was ok.
I was driving a convertable car that the top stopped Half way down on the trip.
Also had no radio.
But all was good.
w111mz
Jan 24, 2013 10:16 AM
Cannondale
Jan 21, 2009 08:14 AM
charlesbattaglia
Jan 19, 2006 11:09 PM
copurnikus
Oct 18, 2005 04:54 PM
EmailBenn
Oct 9, 2005 09:05 AM
