XC90 plug in hybrid charging
Old Dec 15, 2025 | 04:01 PM
thorin's Avatar
Default plug in hybrid charging
New to the forum, I don't see this addressed anywhere.
I am anticipating delivery of a '26 XC90 plug in hybrid. The manual says it can be charged from a standard wall socket but it is not recommended long term. I am trying to avoid the expense of installing a fast charger,
Can someone with experience give me advice about this? Besides slow charging speeds, is there a problem with charging from a 110V wall socket?
If this addressed elsewhere please let me know. Thanks.
Old Dec 15, 2025 | 04:36 PM
requa's Avatar
My experience with my 2025 S60 was that I could charge it on 110, but in addition to taking twice as long to charge, it really needs to be a dedicated circuit. In my situation, the car charger would fail as soon as I added any additional load to the circuit, such as operating my garage door opener. Knowing that I needed to run a dedicated circuit, it made more sense to run a 220 circuit and charge faster. This is a standard 220 v outlet like you use to plug an electric dryer into, not a fast charger like the ones needed for a true EV with much larger batteries. Wait until you see the connector that comes with the car to make sure you or your electrician get the right type of outlet. I hope this helps, and enjoy your new ride.
Dan
Old Dec 15, 2025 | 04:40 PM
thorin's Avatar
Dan
When you say your car charger would fail, do you mean that a circuit would trip and interrupt the charging? Or do you mean the charger itself would be damaged?
Old Dec 15, 2025 | 04:51 PM
requa's Avatar
Sorry I wasn't clear about that. I don't think it was tripping the breaker (this was a year and a half ago). The indicator light on the Volvo charging unit would flash red and stop charging when it detected the fault. I think I had to unplug it to reset it. I eventually started using an extension cord from a nearby outlet on a circuit that was not otherwise in use until I could install the dedicated line.
Old Dec 29, 2025 | 07:35 PM
thorin's Avatar
Update on charging my '26 XC90 PHEV - I've charged it twice using a 110V plug in my garage. No problems, goes from 0 to 100% charge in about 14 hours. Perfectly adequate for running errands and then recharging overnight. The one time I emptied the berry on the road it converted to hybrid mode with the ICE coming on smoothly.
I am seeing information various places that the best practice for battery life is to keep it between 20 and 90% charged. Am I compromising battery life by charging to 100%, and by letting the battery drain completely? I I find the online Volvo manual less than informative on this and related issues and would be interested in any knowledge (or source of information besides YouTube videos) that anyone can offer.
Thanks for your help
Old Dec 30, 2025 | 06:30 AM
Bill50's Avatar
We have owned an XC60 plug in hybrid for two years now and regularly charge it fully using a 110 outlet - never had an issue with the power cord/charger supplied by Volvo with the car. However, like you stated it is common advice for "full electrics" using lithium ion batteries, like the style Volvo uses, to charge them to 80-90% and to recharge around the 20% level. So I too wonder does the plug in hybrid process of fully using the battery capacity and fully recharging degrade the battery more quickly than the 80/20 rule? It is common advice/practice with all makes of plug in hybrids, not just Volvo, for owners to fully use the available battery capacity and then fully recharge. Is there something about plug in hybrid batteries that is different than fully electric batteries??? Does anyone know the answer?
adiggy
Feb 21, 2023 06:29 PM
skeeter1966
Sep 6, 2022 11:03 AM
johnsonx42
Sep 20, 2016 05:23 PM
Northboundndown
Aug 21, 2013 08:19 PM
bobloftus
Jun 13, 2010 08:11 PM
