'00-'04 S40 Fuel Pressure Regulator replacement guide
Old Jan 18, 2016 | 07:19 AM
  #21
kolekjk1's Avatar
Default Replacement Issues
Hi, I replaced my FPR and the car worked great yesterday. This morning I went to start it and it turns over but will not run continually without my foot on the gas. There is a 20 degree colder temperature this morning. could there be a vapor lock if the system was not repressurized? I replaced the whole assembly with a new Volvo part. Has anyone else had this issue?
Jerry
Old Jan 18, 2016 | 03:57 PM
  #22
Hudini's Avatar
Check the Idle Air Control motor and the small S shaped hose between the front intercooler and the throttle body. Unfortunately I've replaced all 3 things, IAC motor, FPR, and hose. Not at the same time though.
In this pic you can see the S shaped hose (where it starts in the red box). It connects to the throttle body area on the other end. You can also see the Idle Air Control motor.
Old Jan 19, 2016 | 05:52 AM
  #23
kolekjk1's Avatar
Default FPR Issue
Hudini, did replacing all three part fix the starting and running issue?
Old Jan 22, 2016 | 11:03 AM
  #24
Hudini's Avatar
My symptoms were a long cranking time before it would start and run. But if you held the throttle plate open a bit it would start right up but not idle immediately. So my first reaction was to replace the Idle Air Control motor which did not fix it. Next I read this very forum and discovered the FPR. After replacing that it started and ran fine.
Years later I was getting a very strange idle behavior and found the S shaped hose cracked in two. It was different than the long cranking time associated with a bad FPR.
Old Feb 25, 2016 | 10:03 PM
  #25
S40_Casey's Avatar
It appears your photos are down and I cannot view the photos. Can you check to see that they are uploaded correctly? This is the only legit guide I found online after much searching, but cannot see the photos. Would be very helpful!!
Old Feb 26, 2016 | 04:19 PM
  #26
Chris Raab's Avatar
Default update best price i found for the fpr !!!
Bosch 3-Bar Fuel Pressure Regulator
Old Feb 26, 2016 | 11:26 PM
  #27
Hudini's Avatar
I can see them. Is Photobucket blocked where you are?
Old Feb 27, 2016 | 06:54 AM
  #28
s40_Ontario's Avatar
If you order one of these Bosch units for VW, let us know if it fits. I recall looking at them and think they are different dimensions from the Weber unit on the Volvo. The price we have to pay for our units is crazy but it I guess the volume is lower.
Originally Posted by Chris Raab
Old Mar 3, 2016 | 12:46 AM
  #29
S40_Casey's Avatar
What is the S-Shaped part called just beneath the FPR assembly that connects directly to the FPR? Should that be replaced too? It seems odd not to just replace that part as well, but the FPR I bought did not come with it (circled).
Part link: BWD 24114 - Fuel Pressure Regulator | O'Reilly Auto Parts
For My 01' Volvo S40.
Old Mar 3, 2016 | 06:41 AM
  #30
It's a vacuum hose. If the black rubber remains in good condition, reuse it. You can but it separately if you need it.
Fuel Pressure Regulator Vacuum Hose - NEDCAR S40 V40 GENUINE VOLVO 121756 9202717
Old Jan 19, 2017 | 11:53 PM
  #31
Shane's40's Avatar
Default I'm having bad time with the fuel pressure regulator
im havi
Old Jan 20, 2017 | 09:02 AM
  #32
I did the FPR on my 00 S40 this past summer. The only CEL code was for a generic misfire. The main symptom was excessive cranking at start up. To replace requires two different size torx bits along with a flat blade and needle nose pliers to separate the fuel line connector and to slide off the vacuum line. Not very much fuel will leak out but have a clean up rag. The whole job is about 15 minutes.
Old Sep 10, 2017 | 05:45 PM
  #33
pmondrian67's Avatar
I am also not able to view the pictures. I don't believe I am being blocked. When I goto Imageshack, it says the files do not exist. Can anyone else see the pictures, or post them?
Thank you.
MntnDewMan
Apr 3, 2024 04:05 PM
NYs40turbo
Jun 8, 2013 03:25 PM
slsnumber1
Mar 15, 2011 02:55 PM
cshutts
Apr 29, 2009 05:02 PM
IdleTime
May 29, 2008 04:01 PM
