'00 S40 - Can bad coolant temp sensor actually prevent starting?
Old May 29, 2013 | 08:36 AM
stevetro1's Avatar
Default '00 S40 - Can bad coolant temp sensor actually prevent starting?
Hi all,
You can browse my longer more detailed post on my issue here:
https://volvoforums.com/forum/volvo-...g-steps-71242/
But I was wondering if a faulty coolant temp sensor could actually prevent the car from starting? I ask this because I noticed when I attempted to start the car cold again this morning to no avail, the fans kick right on as soon as I turn the key off. The started turned maybe 4-5 times. After the fan shutoff I just turned the key on and off, no starter attempt, and the fan went right back on.
Seems strange, and I have been having odd temperature issues.
Old Jun 4, 2013 | 09:24 AM
Hudini's Avatar
I have heard of a faulty MAF causing the fans to run when they should not. No clue why the MAF would cause this.
Old Aug 5, 2014 | 01:00 PM
m_chewan's Avatar
Default Any solution yet?
Im having similar problems with erratic hard starting and fan coming on when cold. Did you replace the coolent sensor and did it solve your problem?
that4wdwagon
Sep 1, 2014 03:39 PM
cisopen
Sep 20, 2010 05:25 PM
mschenkel
Dec 30, 2009 08:45 AM
angel308
Jan 23, 2008 06:36 AM
