2002 S40 coolant temp sensor install
Old Feb 10, 2006 | 12:38 PM
angel308's Avatar
Default 2002 S40 coolant temp sensor install
Can anyone direct me to information or does anyone know how to install a coolant temp sensor in a 2002 volvo s40?
Old Feb 10, 2006 | 02:57 PM
rjolly's Avatar
Default RE: 2002 S40 coolant temp sensor install
I had to change my temperature sensor on the '02 S40 to get the check engine light to turn off (with the light on, I cannot register my vehicle in the state of California). I got my theromostat and temp sensor (the mechanic said they had to do them together) replaced at a Volvo Repair Shop for $150.
Old Feb 11, 2006 | 05:45 PM
It is very easy to replace. The thermostat will come out after you remove the 2 torxes 45 I think screws. Then when you have the top half of the housing off the sensor can easily be removed.
Old Jan 22, 2008 | 07:17 PM
bseven7s4's Avatar
Hi,
I just got a 2001 Volvo s40 and I need to replace the temperature sensor + thermostat in order to pass Wash,DC inspection...i have the both temp sensor and therm but I don't have enough money to pay a mechanic to perform the work...can someone please instruct me on how to install both? Your help will be greatly appreciated.
Old Jan 22, 2008 | 07:36 PM
It is pretty easy to install.
Follow the upper hose to the engine. Where the upper hose attaches to the engine is an aluminum piece.
It has 2 screws holding it on. Remove the 2 screws then remove the upper housing the thermostat.
The sensor screws in the lower housing.
Old Jan 23, 2008 | 06:36 AM
mcguij1's Avatar
for some pictures and a how to guide you can try S40concepts.net, but I don't know if they have the sensor, I know they have a how to for the thermostat.
stevetro1
Aug 5, 2014 01:00 PM
jrichardson
May 24, 2012 01:06 PM
cisopen
Sep 20, 2010 05:25 PM
angel308
Feb 10, 2006 12:38 PM
