01 s40 still hard starting
Old May 4, 2009 | 11:48 AM
ty672's Avatar
Default 01 s40 still hard starting
so far i have checked the battery, plugs, and starter those were all fine. I have now replaced the fuel pump and pressure regulator. Still takes 5-10 secs to turn over....
anything else im missing?
Old May 8, 2009 | 11:00 AM
simmonswil's Avatar
Default hard starting, stalling after start
I have an '01 S40 that was having the "Hard Start" problem. I replaced the fuel pressure regulator, but that did not fix the problem. Took it to the dealer after the car started stalling. They replaced the idle air controller and it fixed both probelms (hard starting and stalling). The idle air control valvle is on the front of the engine and is very easy to replace. just remove 2 10mm bolts and unplug the wirinig harness. You might want to try replacing it to see if it helps.
manwithvolvos40
Sep 3, 2011 08:52 AM
hank.knowles
Aug 29, 2009 02:52 PM
rickrarey
Nov 15, 2008 03:20 PM
Lyonsroar
Oct 21, 2008 05:18 PM
bigdaddyrdpjr
Sep 9, 2007 10:30 PM
