2003 S40 Hard starting..
Old Apr 30, 2009 | 02:30 PM
hank.knowles's Avatar
Default 2003 S40 Hard starting..
Well my niece's car is giving me fits, Here car began hard start in the morning only after the initial start it would behave normally! I replaced the FPR and the problem went away for a while then she said it started up again. Part under warranty from rockauto so I replaced it and there is not much difference. Can anyone offer other possible diagnostic possibilities or parts that could be failing - I have replaced the plugs initially!
Thanks
Kind Regards,
Hank Knowles
Old Apr 30, 2009 | 06:59 PM
It is hard to say can you get a fuel pressure guage to test the pressure?
Old Apr 30, 2009 | 08:51 PM
sghokie's Avatar
Does it start better when you put your foot on the pedal?
Maybe the idle air valve is stuck.
Old May 1, 2009 | 12:14 PM
I'll have to get one to do that! Maybe on the weekend Thanks
Old May 1, 2009 | 12:15 PM
I'll have to ask her - where is the idle air valve located?
Old May 1, 2009 | 07:54 PM
It is on the front of the intake like under the black cover that you remove with the 2 screws.
Old Aug 25, 2009 | 11:59 PM
ricky's Avatar
hi, did you replace the 'idle air controller'? it fixed your problem?
thanks
Old Aug 29, 2009 | 02:52 PM
Lyonsroar's Avatar
Try cleaning the IAC first, if that doesn't work then replace it. It's not a very expensive part.
Spray the sensor out with carb cleaner.
Pretribrapper
Aug 5, 2014 08:23 PM
Pretribrapper
Jul 20, 2014 10:36 PM
jtmeiners
Jun 14, 2011 10:55 PM
ty672
May 8, 2009 11:00 AM
Lyonsroar
Oct 21, 2008 05:18 PM
